us red fans
sorry, i meant ones that are just red uv reactive (no leds, and only red), i cant find them any where!
Hmm... Well if all else fails you could get a clear fan and paint it w/ UV reactive red clear coat.
that is a brilliant idea! but how would i got about doing that, just painting it (cant it "hurt" the fan).
I know I saw a guide somewhere... I'll try to find linkage
#edit#
Yay! Linkage found! A quick Google search turned up this pretty cool article! I guess you just could use UV reactive clear coat, available at svc and others instead of standard paint! And once you've removed and painted the blades, I don't think it would be very hard to paint the frame with the blades out.
