All products are used unless stated otherwise. Please PM me or post here if you have question about something before buying it.
1) EVGA GTX 980ti SC+ : $275 - Sold
Used for about a year. Purchased 7/15/2015 which leaves about 2 years of warranty on it.
http://i.imgur.com/yZVWQl0.jpg
http://i.imgur.com/S93RVCO.jpg
http://www.evga.com/Products/Specs/GPU.aspx?pn=3CDFAB4C-0EAB-44B7-8F32-2A6780A37C4B
2) EVGA 1300w G2 : $150 - Sold
Used for 6 months then downgraded to an 850w. Purchased 7/02/15
http://i.imgur.com/DgVy5ya.jpg
http://i.imgur.com/i6xvtKD.jpg
http://i.imgur.com/fE3TQCA.jpg
http://www.evga.com/Products/Product.aspx?pn=120-G2-1300-XR
3) Ducky Shine 5 Cherry Red switches : $115
Everything works great on it I just didn't have a need for the TK so I changed to a ducky one TKL.
http://i.imgur.com/cpe9HQo.jpg
http://i.imgur.com/jiWHvpd.jpg
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=1367
4) 2x EVGA 480 : $30 each / $50 pair
No heat sinks or original boxes. One of them appears to of had a cap replaced by someone else.
http://i.imgur.com/L3Mm6W0.jpg
http://i.imgur.com/JbmpPvB.jpg
No specs
5) Gigabyte Z97x SOC Force : $125
Covered in plastidip and ready for subzero. Used it several times and it is a great board just no use for it. The platidip can be removed if you want to do so. Includes the IO Shield and OC.
http://i.imgur.com/8MjZPuU.jpg
http://i.imgur.com/Y3Cwoef.jpg
6) Asus Rampage Extreme LGA 775 : $175 - Sold
Bought this and tested it with the processor it came with. Everything seems to work fine. Includes IO Shield but no original box or other accessories.
http://i.imgur.com/ebwQc9n.jpg
https://www.asus.com/Motherboards/RAMPAGE_EXTREME/
7) Open Bench Table community edition: $150 - Sold
Purchased during the preorders. Never used it as I don't really have time anymore with school. It has been opened and setup once for pictures. Comes in original box with the travel sleeve
http://i.imgur.com/Flml7Mb.jpg
http://i.imgur.com/MUTnLMX.jpg
https://openbenchtable.com/
8) KingPin Dragon CPU Pot : $115
Original dragon pot so it isn't anodizied. Comes with K-Type Probe
http://i.imgur.com/zPai0rT.jpg
9) 2x KingPin Tek 9 Slim : $110/$200 both
https://kingpincooling.com/collections/extreme-pc-cooling/products/tek-9-slim
If you buy both the GPU and CPU pot I will throw in the pelican case.
Heat: http://www.heatware.com/u/80411
No specs
