enyceexdanny
- Sep 22, 2003
Hey guys. I have a favor to ask of you.
Below is my current setup:
- Intel Core i7 950
- EVGA E770 Classified 3 motherboard
- Corsair HX1000 PSU
- Corsair Dominator GT 1866 DDR3 Memory (3x2gb)
- XFX 5970 Black Edition
- Lian Li PC-1200V Plus II
- Swiftech Apex Ultima (CPU only)
Here's my situation:
I want to totally re-do my entire watercooling setup. I'm going to give my current setup away to a friend. I'm thinking of replacing my case as well, to the Corsair Obsidian 800.
The prerequisites:
- I am fairly new to watercooling and don't have much knowledge regarding it. My current setup a friend has helped me install.
- I would like to watercool not just the CPU, but the motherboard and the GPU.
- Need something that's easy to maintain. MY current setup I haven't flushed ever since it was installed, which was over a year ago. Surprisingly, it's still performing well. I've used distilled water + fluid + waterwetter (which seems to have helped in keeping the loop algae free.)
- Pricing is not really too much of a factor. I just want it to be worth my while.
The favor:
I would greatly appreciate suggestions for the entire setup parts. Since I'm pretty new to watercooling, I would appreciate as detailed list of items that I'll need. (e.g. tubing, fitting, barbs, radiator, pumps, etc). Also would appreciate some guidance in how I should set it up. (e.g. dual vs single loop. Where to place the radiators (if dual), etc.)
Thanks!
Edit:
Below are the current parts I'm looking at. Please share your thoughts.
From my current setup:
- Swiftech MCP655 Pump
- Swiftech 240 radiator
Already purchased:
- Corsair Obsidian 800D Case
- (20) Bitspower Ultimate G 1/4 Thread 1/2"ID x 3/4"OD Compression Fitting
- (5) Scythe Gentle Typhoon 120mm High Speed Fans (For the 360 Radiator)
Still waiting to purchase:
- EK Supreme HF Full Copper/Nickel CPU Block
- EK-FC5970 Radeon 5970 Reference Design Block
- XSPC RX360 Radiator or the new TA120.3 if it's available within a few days.
- Bitspower D5/MCP655 Pump Replacement Top Version 2 BP-D5TOPP2-BK (For cleaner/easier dual pump placement)
- (2) EK Multioption RES X2 - 250 Advanced
- EK-FB EVGA X58 Classified Full Board Block (Compatibility with E770 is pending)
- (3) Noiseblocker NB-Blacksilentpro PK-3 140mm Fan (Replacement fans for obsidian case)
- (2) IandH Silver KillCoils
- (10 feet) Tygon R-3400 1/2"ID (3/4" OD) Black Tubing (Still contemplating if the primoflex pro would be better)
Total comes out to almost 1500 after shipping.
EDIT (10/25):
This is how I'm thinking of cooling.
- 360 Radiator along with (1) MCP655 pump will be cooling the CPU + Motherboard (NB/SB/MOSFETS)
- Swiftech 240 Radiator with (1) MCP655 pump will be cooling the XFX 5970 BE.
Would that be enough? Any suggestions?
Questions:
- coming soon.
- Intel Core i7 950
The prerequisites:
The favor:
Thanks!
Edit:
Already purchased:
EDIT (10/25):
Questions:
- coming soon.
