Urgent Koolance Question
Zeke
If the fluid level is above the marker that says "high" on my water pump, is that not good? Should there be a little air in there? I mean, it's a water pump so it shouldn't need any air by definition? PLEASE HELP, i dont wanna burn up my stuff...
As long as it's not completely filled to the top it should be find. You should always see a little air in the system or be able to see the water moving in the resevoir. If not then there's a bubble somewhere keeping the water from moving.
