Urgent Help Needed TODAY on Mobo & CPU...PLEASE
cowboiup
My Motherboard burned out on me and I need to get a new one. Things have changed so drastically since I bought my last processor (a AMD Barton) and motherboard (a piece of crap MSI K6V Series), so now I am using an OLD (Compaq P3, 64mb mem...slower than molasses) until I can get a new processor and mobo. My drives are SATA so I can't use them on here, in fact I can't even use a SATA card on this thing (I tried), so ALL my files, programs, etc., are on drives I can't access until I get a new CPU & mobo.
My problem is that I'm not sure what the heck the difference is anymore between all the CPUs and then what is and is not a good board anymore. All I know is that I have a decent AGP Graphics card, 3 - 512 & 1 gig of DDR400 memory sticks, 3 SATA drives, so I'd like to be able to get back up and running as quickly as possible, but also as cheaply yet good/fast/dependable as possible. Like I'm willing to hold a few more days to order one if it is cheaper or better than going to say Fry's (outpost.com...they have a store here) jst to be able to get something today.
I was thinking that the AMD Opteron 248 (not sure which of the 3 or 4 or even what the differences are) or else the Intel P4 Dual and that's as far as I've managed to get.
I would really like a board that could use my current memory or does both DDR & DDR2 (that'd be great...then I could upgrade a little later on), but that would eliminate one more cost in not having to get new memory immediately. One that has SATA ports, has AGP (again I have an AGP Graphics card, so that would be one less cost), onboard sound & ethernet port.
Aside from that I'm at a total loss...I've tried looking at Newegg, Zipzoomfly, Tigerdirect & Outpost...only to get more confused that I started, IF you can believe that!!!
socket 754 for amd, no dual core on 754 as of right now, not sure if there will ever be, heard some talk today of it something to do with turion but disregard that.
socket 754 has agp as socket 939 does not. well i think there are a couple boards that have agp for 939 but i think they are cheaper boards etc...not real sure
besides that intels side im not too familiar with other than socket 478 pentium 4's.
mainly u want to check if board supports ur current ram, and what are your uses for CPU, if ur a gamer id go with nothing less the 2ghz some might say nothing less than 2.2 or 2.4ghz.
take a look at the specs most modern mobos all have SATA, some brands which may already know, asus, gigabyte, DFI for overclocking, when looking at mobos another thing to keep in mind is the chipset, ive been happy n pleased with Nforce3 and Nforce4 models ive not dealt with ULI or VIA for awhile now.
heres a nice deal gigabyte socket 939 with AGP, supports SATA and pc3200 400mhz ram, and id suggest a socket 939 opteron 165 dual core CPU as they are highly suggested and for good reason they are server CPU's and are a put under a bit more stringent testing than the X2 dual cores.
http://www.newegg.com/Product/Product.asp?Item=N82E16813128286not sure if this motherboard supports opterons or not, some only require a updated bios. if u turns out that mobo doesnt support opterons, id suggest the 3500+ s939.http://www.newegg.com/Product/Product.asp?Item=N82E16819103603
im sure u will get more feedback soon and you will have all the info u need to decide and any thing at all, just post we will be more than glad to help.
