URGENT Help needed! Please read...
collegeboy69us
hello,
Right now im in the shitter -- i *think* my motherboard is dead but i need some input from you guys. Last night i tried a little overvolting on my K8N neo2 Platinum... and it booted got to logon screen and crashed. So i figure okay ill lower my O/C and try again. (im watercooling an AMD64 3200+ Winchester)
I think it was a heat issue, because ive had it automatically shut the comp down when there was a heat overload, i let it cool down for 30 min come back to power it up... nothing. The fans on the mobo twitched and in the PSU twitched but nothing. I played with it for a little while and got nowhere, i took the bios battery out reset the Cmos jumper and let it sit over night without the power plugged in. This morning i get up and mess with it some more I have found the following: The power supply is perfectly good, i tested it in another machine. When i just have the 20 pin ATX connector hooked in... it powers up the board. BUT when i plug in the required 12V square motherboard connector it goes back to doing what it was doing, the fans twitch and nothing. *This is an Antec 350W psu that has worked flawlessly for months.
I need some help here -- I'm going to guess the board is fried somehow? This is the only 64bit cpu and mobo in the house (and we live in the middle of nowhere) Options? Suggestions? Ill be checking back every 10 min here. I appreciate any help you guys can offer.
Does the other board you tried have the 12V connector as well? If you have a multimeter, check the output on that 12V connector from the power supply. Also have a look at the pins inside of the connector on the mainboard to make sure none are bent or otherwise damaged. If all of this looks ok, you probably fried something by overvolting. Did you happen to notice a burning smell coming from the system before it crashed?
