Ur opinion on this PSU?
The Topower doesn't have all that much combined +12V output, only about 33A from what I can see. The Liberty 620W and Silverstone 600W are pretty good choices, but the Silverstone 650W would probably be pretty loud and isn't modular. I only like the Seventeam ST-750EAJ out of the three as it's got two 80mm fans, which should mean more quiet. It's got a stronger 12V4 too.
What are you trying to power exactly?
check out the enhance modular 600w that ewiz is selling ... jonnyguru says it's an oem unit that supose to go to system builders but ewiz is shorting them and selling to the public
under 100 for the same exact unit as the $160 silverstone modular 600w quad rail (is that the strider) can't remember ...
anywho.. check it
mal
p.s. i personally just bougth a xfinty 500w for 57 shipped to my door yesterday from www.overcool.com
They're not exactly the same, from what I know. The high-efficiency Enhance 500W models get a special place in Silverstone's lineup. They're probably are built by Enhance though.
nice find no? was on jonnyguru's blog
have to take into consideration the warranty and customers service of an oem part though..
mal
I bought the enhance at ewiz. ordered tues or wednesday, had it by friday. it's the exact same as the Silverstone, from all the silverstone pics I've found.
only one little detail though...
the cables included:
the main one.
pcie connector with 2 pcie plugs
1 molex cable with 2 plugs
1 molex cable with 2 plugs & floppy
1 sata cable with 2 plugs
and a couple of weird ones.
the retail silverstone comes with 4 molex cables... 2 with floppy connectors, and all 4 cables have 2 molex plugs. also, retail silverstone comes with 2 sata cables each with 2 plugs.
so just missing three cables:
one sata cable
one molex w/ 2 plugs & floppy
one molex w/2 plugs
HighwayAssassins said:
if you NEED 600W disregard this post.
I have a OCZ powerstream 520W PSU and swear by it.
yea those Topowers are pretty good too
If you want a quiet PSU, I just got the Enermax 620W modular yesterday. I plugged it in and tripped the power-up wires just so I could make sure it wasn't DOA and voltages were sweet...... it was sitting on the bench (not in the case) about a foot 1/2 away from my head and I couldn't hear the PSU fan at all.... pretty dang quiet :) Admittedly the fan was at it's lowest speed (no load) but not too shabby :D
