Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Stick with name brands, APC, Belkin, Cyberpower are the popular ones on newegg. I don't know of any sites that specifically cater to UPS reviews, but the [h] can help you out with selection if we know your loads/needs
Stick to the popular brands and make sure it has the wattage you need. A UPS is meant to keep your system running so you can save your work and shut down, even if it's for five or ten minutes.
Also look into a UPS with voltage regulation/stabilization.
