ups recommendation needed
onlymeme
I just know the basics about ups and certainly not enough to make a wise choice so I'm here looking for advice.
Basically I need a ups for my server which holds all my media. I'm adding adding hdds as needed and it will end up with around 30 5400 rpm sata II hdds. It's a i3 with an old radeon 3450 (if i remember it right). The psu is a corsair hx-1000.
basically i need the ups for a safe shut down or for 10-20 minutes tops.
what do you recommend?
thx
I would look at the apc website and plug in some of the info you know and then extrapolate.
For example, 30 HDD's will not be an option in their dropdown :)
