ups batteries
tunatime
Well...OK
whats yall go to store/ brand for ups batteries? my 9px could probably do with a new set soon. a new set 20 cbs are about 20 each where knock offs are about 12-15. are they all made in the same place in china and about the same?
SLA batteries are not all created equal. The cheap shitty ones usually have shorter and/or thinner lead plates that reduces their useful life dramatically, as well as their output. You can generally tell how good a SLA battery is by its weight, or lack thereof.
I'd recommend Yuasa or Universal battery for SLA batteries. They're more expensive, but worth it. The only issue with buying them piecemeal is you have to rebuild the battery modules yourself, which can get a bit irritating if there are more than two batteries. It can also get a bit dangerous if a lot of batteries are in series, high voltage DC is nothing to mess around with.
