Zorachus
- Dec 17, 2006
I have a pretty nice motherboard I believe, in the Intel X48 chipset, brand = Asus Rampage Formula, I am running Corsair DDR2 PC-8500 memory 2 sticks of 2gb each = total of 4gb 1066mhz memory.
Anyways the memory says it is best to run at 2.10 volts, but the motherboard default is 1.80V, so I had to bump up the voltage higher, is that a problem ? The manual says if lights on mobo still green means "normal" OC, yellow measn "high" , and Red they call "crazy" OC.
I also bumped up the NB voltage to 1.40V, I hear that is better for OC ? And lastly had to go into bios and set DRAM speed to 1066mhz.
Is all this ok ?
Is all this ok ?
