denizenzero
- Sep 19, 2005
I have network discovery enabled but for some reason upnp does not seem to be working. Windows Firewall also does not have a check box for upnp like it used to in windows xp. Router is a D-Link DGL-4300 with exact same set up that was previously used in Win xp w/ Upnp working.
Basically I don't want to have to worry about manually forwarding ports for bit torrent etc to each user that wants to use it on my home network.
Vista is seeing the router etc and even auto configured the network upon install but upnp does not seem to work.
Any suggestions or ideas would be great. I may just have to bite the bullet and configure port forwarding though.
Thanks!
Thanks!
