Cmustang87
- Oct 4, 2007
Afternoon,
I have a minor issue that has been kind of rattling my brain. I have 2 xbox 360's at my place, and we have 2 seperate live accounts and we get online simultaneous. I have ports 3074 and 88 forwarded to my xbox (192.168.1.104), it is static'd out. I know you obviously cannot port forward to 2 devices.
The router I use is a Linksys WRT610N and I need to have the open NAT on both the systems, and I read that it's best with 2 xboxes to disable all port forwarding to the systems and have DHCP enabled on them, and have uPnP on. Xbox live uses TCP/UDP ports 3074 and 88.
Is this the right answer? How secure is uPnP if I have all remote administration disabled (you can't manage the router unless you're wired to it)?
