Was finally able to test out my ARC-1883i on a decent board rather than the (admittedly) bargain basement AMD board I have been using for years, and works great. I used my desktop's Rampage III Gene and put the card into PCIe slot 1, which I didn't do before, and worked perfectly.
I've finally decided to just step my game up and upgrade my home server full hog. I'm looking at either a Rampage III Extreme or a ASRock C226 WS+ board. The R3E offers me the cheap Xeon 6 core and 48GB ECC RAM, but it is outdated with the mediocre Marvell SATA controller. The C226 is newer, but only 32GB RAM and 4 cores.
Additionally, the C226 route would give me onboard video which is fine, but the R3E I would have to buy another video card.
Lastly, the R3E has a bit of a following on bios-mods, so I can at least get OROM upgrades pretty easily enough. If I get the ASRock or almost any other workstation board I'd be on my own and have to rely on the vendor for BIOS updates.
I'm really thinking the extra memory, 2 cores/4 threads and ROM upgrades are worth the higher priced X58 board option. Expensive as hell on eBay and whatnot. Is there something drastic with the C226 board I'm missing that is more worth it?
Thoughts?
Thoughts?
