upgrading to the 6600gt
maXXspeed
hello all,
i am looking at the 6600 GT for a upgrade card. my motherboard is a msi k7n2 delta L.
it supports AGP 4x and 8x. the 6600GT im am looking at is a PC Express supported card. does this mean it will work in my 8x agp slot, or would that type of card only work in a motherboard with a PC Express slot?
thanks
maXX
thanks, i wasnt sure.
ill just look for the agp type. im sure i can find it.
thanks again for your time
maXX
neweeg.com is out of stock right now. 225.00
i checked provantage.com also. they are out of stock there too, but the 6600gt is only 218.00 there.
as soon as one of those stores has the card instock, im ordering one!!
i cant wait
maXX
Unless you are tight on cash and $200-225 is your absolute limit, you might consider the 6800.
i ordered the 6600gt agp 8x.
it will be here friday!!!!!!!
i cant wait to try it out.
maXX
