I built a new rig 2 years ago and due to budget constraints I decided to forgo a monitor and just use my 40inch TV. That has worked pretty well, but now I'm wanting to put my computer in my office where I can use it while my wife and daughter use the TV. I would like to go to a 3 screen setup. This will primarily be used for gaming but I will watch the occasional movie as well. I would like to go with either 23 or 24 inch screens and I'm leaning toward IPS or VA.
My budget is $1500 absolute max. Really I'd prefer to keep it closer to $1000 if at all possible as there are other projects I would like to put that money toward. I have been looking into the Dell P2414H and Eizo Foris FS2333 but I am certainly open to other suggestions. From what I have seen the Dell looks like one of the more affordable options.
My current rig's specs are as follows:
i5 2500K
8GB RAM
Gigabyte 7950 3GB
Corsair 650TX V2 650W PSU
If I need to upgrade anything then that will also have to come out of the above budget. Any and all suggestions are appreciated.
Edit: I mostly play RPGs (Skyrim, Diablo 3, etc.) but I also play shooters (Bioshock: Infinite, Borderlands, etc.).
Edit 2: I would also like to make sure that the monitors can be wall mounted.
i5 2500K
8GB RAM
Gigabyte 7950 3GB
