Upgrading to a Smaller Package
Crimson Tear
I've been out of the game for a long time, but I find myself in need of a smaller PC and even when I was staying up on the current tech, I didn't know much about building small systems. I'd like to end up with something in a package less than 13" tall with a nice minimal look, in black. I'm currently using a rather large, but beautiful Lian-Li case with an i7 920 and I'd like to downsize and upgrade these.
So far the case I'm liking is the Corsair Obsidian 250D, but I'm open to ideas. One troublesome piece I've found is that my PSU is rather large. I'm open to the idea of replacing it. I'm a bit partial to Intel. I'd appreciate any help you all can provide in finding a case, CPU, and motherboard. Standard questions below:
1) What will you be doing with this PC?
- Gaming, web browsing, media consumption
- I'd like to keep it in the ballpark of $1000 or below, all told.
- Florida
- Case, motherboard, CPU, RAM
- PSU: Corsair CMPSU-1000HX (1000 watt, 8" length)
- GPU: Zotac NVIDIA GeForce GTX 970 4GB GDDR5
- SSD: Samsung 840 Pro
6) Will you be overclocking?
- No
- Dell U3011 2560x1600 (for now)
- Immediately
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
- Just the basics. No need for onboard sound, but I do want integrated WiFi if possible
- Yes, 64bit Windows 10
Just so you know the latest CPUs use DDR4 memory so you won't be able to reuse your RAM unless you get outdated hardware.
I'd be looking at i5-8xxx (Coffee Lake) systems as a starting point. You could probably get away with an i3-8xxx, but I believe the two additional cores of the i5 are worth the extra cost. Ryzen might be even cheaper, but make sure whatever you're playing isn't one of those titles that seemed to be hobbled by it (or maybe those issues were resolved since the reviews, I'm not sure).
16GB (2x8) of RAM is fine. Since you're not overclocking there's no need to get sticks rated faster than the mainboard/CPU officially support.
The GTX-970 seems under-powered for a 2560x1600 display, though I suppose it depends on what games you're playing and the quality you're comfortable with.
I'd consider replacing the PSU solely based on it being massively over-specced for anything outside of an overclocked multi-GPU system. A quality gold-rated unit (e.g., Seasonic) in the 400-500W range is more than enough.
