Upgrading the Antec Aria
holliswhy
kk, using the Antec aria, have P4 3.0 (Extramely hot version), 6600GT AGP, Wireless lan card and Audigy.
Case modded with an external fan blowing straight in the CPU. Playing games at 66oc is.
Looking to get Maxtor Diamond Max 10 250GB 16MB buffer SATA.
Just wanna ask if this isnt too hot? (hoping to 16 MB buffer would help in multi-task)Using Maxtor PATA 60GB at the moment
Also, i have wanna upgrade GFX, whats the most powerful graphics card the Aria's PSU can handle?
cheers
the 16mb wont do anything for multitasking.
what kind of PSU is it? wattage and ampearge ratings?
really? then which should i get? 200-250GB SATA
Aria original 300W
