upgrading ram from 1066 to 1333
lalali
hey all,
i currently have 2 X 2GB 240pin DDR3 1066 Corsair ram chips in my desktop:(see here).
my motherboard has two more ram slots and the memory standard goes up to 1066: (see here).
so i want to purchase two more ram sticks toget 8 GB of ram, and the ram that i was thinking of were these G.Skills: (see here)
however, these G.Skills are DDR3 1333, so i'm wondering if i add these to the motherboard, are there going to be compatibility issues with the Corsair ram chips that are already there?
thanks much!
Compatibility is not the right word , timing issue's more then likely.
If you have noticed that the performance increase for the AMD platform are rather small. If you compare the fastest DDR2 with the 1600 mhz DDR3 modules available the speed increase wont be something that screams buy buy buy :) .
If you care you can search the forums i have seen and posted in such a topic before maybe 2 months ago orso.
I do not believe you will have a compatibility problem. Most likely all 4 dimms will run at DDR3 1066 anyways because of the processor errata that limits 2 DDR3 dimms in a single channel to 1066. The good thing is that all dimms are 1.5V.
