Upgrading on a budget - $3-400
Dagis
Trying to figure out an upgrade for my friend's computer. Right now his assets are 512MB of DDR333, a 9700pro, optical, harddrive, and peripherals. As best as I can figure, he's going to need a new CPU/Mobo, case & psu, and most likely a copy of Windows XP. What are your suggestions? The best I can think of so far is OCing an XP-M and grabbing an Antec case. Is it possible to go for a low-end 64 CPU? Anything I'm missing?
If you go to NewEgg to get your stuff, you might pull if off. And that's if you don't consider the added costs of shipping, taxes, and other charges. Since buying a new CPU pretty much guarantees a new mobo and PSU purchase in the future, if I were you, I'd shoot for the case first because you can get a new case with a PSU included for about $100 (the Antec Sonata with its 380W PSU is a good choice).
There's a huge problem when going for the processor: since your friend wants an Athlon 64 processor, you won't be able to get the newer version (using Socket 939) for under $200. And, since you can't even get an OEM copy of Windows XP for under $100, there's really no way to get all of them and be under $400 (especially if you live in a state like mine, where you would have to pay shipping charges and taxes on all of your goods). Get the case and Windows XP (hopefully your CPU and mobo can hold out for another three to six months), and then try to raise more money to get the CPU and mobo together. It's the easiest way I could think of to solve your problem.
Socket 939 CPU's for under 200 bones are readily available, actually...the Athlon 64 3000+ runs around $150-160 for the retail version which includes heatsink/fan. A mainboard will run around $100-140 depending on what you get.
Still, it could be tight getting the case/psu, etc and still coming out under $100. In addition to NewEgg, I'd check ZipZoomFly as well.
Check zipzoomfly, lately I've been ignoring newegg. When ordering smaller stuff, I can sometimes slice the price of an order in half compared to newegg because of the free 2nd day zipzoomfly provides on most items.
I stopped using newegg last year when they started outright ripping us off on shipping costs.
Just checked ZipZoomFly... sorry... it seems that it has more things now than the last time I checked.... :p
Like I mentioned earlier, getting everything at $300-$400 will be cutting it very close. If you could leave one thing out of your list, I would suggest that you leave the Windows XP as a separate purchase. With ZipZoomFly, you can get an OEM copy of Windows XP Home for under $100 and an Athlon 64 processor using Socket 939 (the 3000+) for under $200, but adding everything together, I still couldn't get it under $400 without shipping. I'm not saying that it's impossible (I was searching as if I was making the upgrades myself), but it's still very difficult to do without removing one or two items from your list.
Thanks to all three of you for your help and time. It turns out my friend is good on OS, so I'm taking another look at pricing things out. :)
