Upgrading old rig for moderate gaming
SarCastro
Hey there. I'm looking to upgrade my P4 1.6A server into a server/semi-decent gaming rig before I get married and my fiancee/wife puts the kabosh on such things :) And not spend a ton of money doing so... Here's what I've got:
P4 1.6A
2x 512MB DDR333 mem
Intel 865 Perl Motherboard
PCI video (this is a server :)
17" LCD monitor
Looking for something that can run WoW, Half Life 2, Civ IV, Doom 3, and Farcry at 1280x1024 at a decent framerate (FSAA not that important to me). I could search for a 2.6 - 3.0 Northwood P4 to plop in for $150, but would that money be better spent on a new proc/mobo? Would a plain 6600 work or would a 6600GT or 6800 be a better choice? Not looking to spend more than $350... Any ideas would be appreciated.
Best bet would probably be a better graphics card, any of the 6000 series will let you play those games listed. They will be on low settings but hey you'll be able to play
If you pick up that proc you listed for 150, you'll still have a good 200 to play with, and if you look hard enough you should be able to find a used 6800gt here on the forums. Might be ~230 or so, but it'll be great for the games you listed. If you're really firm on the money, then a new 6600gt can be had for ~160 from newegg or a used 6800nu on the forums for ~180. With that extra cash you could pick up a new cooler for it (zalman cf700-cu) and give it a little oc'ing :)
either of those graphics options would be great for all the games you listed there.
I have the 6600GT and I am very satisfied with it. It IS the best bang for the buck, as I bought mine for $130 and it plays B&W2 at full settings on 1280x1024. Then again Im not sure how cpu dependant b&w2 is Im sure you could get the same results.
