Upgrading nForce 2 chipset drivers...
MechWarrior
Slob Ur Knob - $5
Ok. I have some version installed that I dont even know what they are. I am using a Shuttle SN41G2. Can someone tell me how to do this without totally fucking myself over? Including which drivers to use? I am scared shitless of this but it needs to be done im guessing... im using really old drivers heh.
Any help and guidelines are appreciated.
Check out this page ..For driver versions, try the latest and go backwards if needed..See how they work, if system performance is good, nothing is FUBAR'd, then all is good.
o_0
What's so hard about going to nvidia.com, downloading the driver.exe and double clicking it?
Because ive only had nvidia screw me. Even on a brand new installation with the latest nForce drivers. I just tried thisweekend, and finally after an hour said screw it and used the default drivers from the manufaturer of the motherboard. No problems then.
www.nforcershq.com
Anyhoo.. I just installed the latest drivers on my Asus A7N8X-Deluxe v1.04
Have probably installed drivers over a dozen times easily and have had nothing but sucess. Nothing has gone wrong. Although, I am not running RAID of any kind or any SATA devices as of yet.
I usually go in Add/Remove and get rid of the nForce installation, Restart, then hold off on any installations that WinXP may want to do. Then I just run the installation for the unified drivers, Restart, Reinstall video drivers, Restart [if needed.. I installed the latest ATI Omega drivers so needed to restart], enjoy.
