Upgrading My System, Could Use Suggestions!
gr!m
I am looking to upgrade my system. I will be purchasing a new CPU, motherboard, and RAM. Here is what I currently run:
AMD Opteron 144 CABNE 1.8Ghz @ 2.52Ghz
Team Extreem Cronus 2GB DDR500 2.5-3-3-6
Biostar Tforce 6100-939
(Everything listed and more is currently for sale in the for sale section of the forums)
I am looking to upgrade to a dual core system preferably a conroe or other C2D system, but it does need to be built on a budget. I am looking to spend $200 or less on CPU and Motherboard. If I sell my RAM I have now for the expected $200 I hope to have that much to spend on some decent DDR2, preferably a 2GB kit. I am not looking for anything with Mail In Rebates since I have not had great experiences with MIRs.
I was also looking into AMDs new X2 3600+ even though I know it's performance OCed will never be near an OCed e6300 or e4300 it is very inexpensive. I was just interested in some input for my new system.
My thoughts were:
e6300 or e4300 + Motherboard combo when a good deal runs around
Some inexpensive DDR2
The other components I have now are
Sapphire X800GTO2 PCIE video card that is highly OCed
Seagate 300GB HD
And that is pretty much it. Right now I use onboard LAN and Sound.
Input is greatly appreciated thanks.
In HIGH hopes, I hope to have about $400 for CPU, Mobo, and RAM. More if I sell some more of the things I currently have for sale now.
Also something I forgot to ask, if anyone knows of any good OC reviews of the new e4300 I would appreciate it. Also how much of a performance gain would I notice?
You're $400 budget for a Core2Duo/mobo/2gb ram will fall short unless you wait for the E4300 to drop in price to its Q2 pricepoint of $113. Then you could add the GA-965P-S3 ($110) and some g.skill 2GBNQ ($185) sticks and you're good to go once you find some cash for tax and shipping.
You'll notice a big improvement in multitasking as well as anything else you do thats cpu intensive (most games are gpu intensive, so the only games that will see improvement are ones that are cpu intensive).
http://anandtech.com/cpuchipsets/showdoc.aspx?i=2903
