"Upgrading" my Old Rig...Opinions?
Chrs
My motherboard finally died on me after 3-4 years, and I wanted to go ahead and "upgrade" my rig. I plan to use it for light gaming and don't care for OC'ing.
I plan on recycling:
  • Antec Sonata w/ 380W PSU
  • 2 IDE HDs
  • 2 optical drives
I recently bought:
I plan on buying:
It's been 3-4 years since I built my first rig, and everything has changed so much. It's pretty intimidating, but I think I've done my research.
I believe my main issue will be my old PSU having 20-pin connector and the mobo having a 24-pin connector. I've read that I can still use the 20-pin connector, but the video card may suffer since it doesn't have an auxiliary power plug. I really don't want to get a new PSU, but I don't mind getting a 20-pin to 24-pin adapter.
Please let me know what you think.
TIA!
I suggest looking for a better board , i actually just used that board on a build for my fathers machine , while its stable (very slim to no oc' options) its a picky board , via chipset isnt the best either
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130068
i would say thats a better choice, better chipset also
as for your PSU , dont think 380watts is gonna get by with a 8800GT
http://www.newegg.com/Product/Product.aspx?Item=N82E16817189005
thats what im currently using an i have no issues what so ever with it , very quiet , good made psu & it doesn't cost a arm an a leg , hope this helps
Hes getting a 8600 not an 8800 so it should be fine, but i would recommend getting a new PSU ASAP. Wouldnt trust any PSU that comes with a case.
anyways I got the same CPU as what your looking at, It nice for the price and can be overclocked pretty easily.
ASRock AliveNf6g mobo
Thats the mobo im running with my 3800, very stable has some nice overclocking options, and it also has a 20 pin instead of 24 pin. But the only thing is it only has 1 IDE connector..
I didnt find out till i got it, so i had to buy a Sata DVD RW which are super cheap these days.
Like everyone else PSU needs upgraded ASAP.
I do lie the ram for price/performance it is decent ram for a lite gamer and office work. I put it in my parents new rig I built them for christmas and it seem to be fine.
I have one suggestion on the motherboard though. I really like the ECS GeForce 6100sm-m2. I also put it in my parents rig along with a x2 5000 and it work very good.
I agree, go with an NForce or AMD 690G chipset if you want an AMD rig. I also agree that your PSU needs replacing. The original Sonata PSU is rather old by now, and not up to the task of powering a newer system, IMO, or at least powering it efficiently.
PSU FAQ: http://www.jonnyguru.net/forums/showthread.php?t=1036
PSU Suggestions:
http://forums.extremeoverclocking.com/showpost.php?p=1590883&postcount=193
http://www.jonnyguru.com/forums/showthread.php?t=1460
http://www.jonnyguru.com/forums/showthread.php?t=103
I was hoping I wouldn't need to upgrade my PSU.
If I was willing to shell out more money on the mobo, do you think this would be a good option:
MSI K9NBPM2-FID AM2 NVIDIA Quadro NVS 210S Micro ATX AMD Motherboard - Retail
That depends... the following is a cut and paste...
Please answer the following questions with as much detail/specifics as possible, as it will help us help you:
1) What's your budget and what is included in that budget (tax/shipping, keyboard, monitor, OS, etc; if you're not in the US, please specify country)?
2) What will you be doing with this system besides gaming (eg: media ripping/encoding, watching hd videos, CAD, etc)?
3) If you are gaming, what games will you be playing and at what resolution/settings (eg: cs:s @ 1680x1050 w/ no AA/AF)?
4) What size monitor do you have and/or plan to get?
5) What old parts do you plan on re-using?
6) What features do you need/want in a motherboard and briefly, why do you need/want them? (3 pci slots, raid, firewire, µATX, etc)
$100 to $150 for CPU and mobo​
Music, videos, email, internet​
I've been out of it for awhile, so I don't know. It's usually games like Age of Empire type games that aren't too graphic intensive.​
19" widesceen​
  • Antec Sonata case (will be using 380W PSU temporarily)
  • 2 IDE HDs
  • 2 IDE optical drives (can probably cut down to one)
  • A-Data DDR2 800 2GB (2 x 1GB)
  • XFX 8600GT 256MB PCI-e x16
  • 2 IDE ports - I have 4 IDE devices I can reuse
    [*]2 PCI slots - just in case
Sorry, I meant to reply to this thread earlier, but it got lost in the mix.
That board looks fine, since you need 2 IDE Controllers.
