So I haven't been around here much in over a year, mostly cause i finished my comp then.
I'm getting the itch to upgrade it though, so I figured I'd come back to you guys and see what you could suggest.
I WCed it back it the day (ok, like fall '05), and that was the first time I've WCed my comp. Gone through a lot since then (including some unfortunate leaks), and I want to clean it up. You can see my setup in my sig, but I'll grab some links for those of you that don't recognize the parts.
Storm
http://www.swiftnets.com/products/Storm.asp
MCW55
http://www.swiftnets.com/store/product_details.asp?ProdID=337
MCP655
http://www.swiftnets.com/store/product_details.asp?ProdID=144
MCR220
http://www.swiftnets.com/store/product_details.asp?ProdID=390
Masterkleer 7/16" ID (I think that's my ID,
http://www.jab-tech.com/Masterkleer-Tubing-7-16-ID-5-8-OD-pr-3079.html
Also some generic single 5.25" bay reservoir, definitely need to replace this crap. I bought it off some not-so-popular site and it tended to leak out the ports until I went to some extreme measures to force it closed. Generic plastic barbs as well, I sorta stripped some of them in various places, I'll be replacing those too.
Basically what I want to do is redo the tubing, maybe get a new CPU block, and GPU block that's full cover (getting tired of ramsinks). Also looking to WC the NB, because the zalman passive cooler I have on it is just not cutting it for my OCing, gets way too hot w/o requiring an extra fan.
I'm also going to be replacing all my fans. I suppose Yate Loons are the best in quiet performance these days? I want to keep it as quiet as possible while also as cool as possible. Money is secondary to these concerns.
Gonna replace the Res too. It'll be a single bay thing, unless it's got like a forward mounted hole, cause I only have 2 5.25" slots open, and I wouldn't be able to fill it up if it was a double. Looking for a nicely made clear one, so I can see the water flowing. A t-line is also an option, anyone use a t-line?
I'll be replacing my water additive too, after looking around the topics here, seems I made a mistake with what I was using (no, it wasn't some expensive coolant, I used mostly distilled water). Besides the distilled water, I'd like to have a biocide (I think that's the term) in there, and I want it to remain clear for as long as possible. What do you guys use?
Probably keeping the computer itself the same, except for the motherboard, that's fried. I'd like to go with a higher quality one this time (I went a little overboard in looking for bang for my buck there). This is what I had previously:
DFI nF4 Ultra-Infinity s939 (NF4-DAGF)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813136163R
What's out there in the way of mobo's? Don't really want/need to replace my 3000+ CPU, it works fine, and going to conroe would mean DDR2 as well, which I also don't need. Was thinking ASUS, cause I want stability, and they OC well enough, even compared to the DFI lanparties, imo.
I'm probably going to be sticking with my same case as well:
GIGABYTE 3D AURORA GZ-FSCA1-ANS Silver
http://www.newegg.com/Product/Product.aspx?Item=N82E16811233001
It's got 2x120mm fans in the back, although with my current rad I'm gonna have to switch it around and put the rad on the outside of the back, cause I can't fit my PSU or case door shut with the Rad on the inside back (so close on both, it's the lock that stops the door, and the little hump on top stops the PSU by like 1/2").
Feel free to comment on any of this.
Storm
MCW55
MCP655
MCR220
