Hello, need some help on what to upgrade since my current system slows down quite a bit when working in Illustrator, Photoshop, Lightroom, Web
Current System:
GIGABYTE GA-Z68A-D3H-B3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
i5-2400 @ 3.10GHZ
12GB RAM:
--- 2x G Skill Intl F3-10600CL9-2GBNT 2GB
--- 2x4GB G.SKILL Sniper 8GB 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666)
MSI GeForce GTX 560 Ti (Fermi) DirectX 11 N560GTX-Ti Twin Frozr II 1GB 256-Bit
Samsung DSpinpoint F3 1 TB SATA 3.0 Gb-s 32 MB Cache HD103SJ
+ 640GB Western Digital HD
Crucial M4 2.5" 128GB SATA III MLC SSD
Corsair Carbide Series Black 400R Mid Tower Computer Case
Antec NeoECO C NeoECO 620C
Photoshop, Lightroom, Illustrator, office, web.. I want to be able to work efficiently between Photoshop and Lightroom while working on big .TIFF/.DNG images. - no gaming in the near future. Illustrator and office is usually also open for work related stuff.
For upgrades ill put my budget below $600. If a new system has to be built, i might revise the budget. But i want to take as many parts as possible into a new system if needed.
California
Not Sure, I'm thinking that the motherboard and CPU needs to be upgraded. maybe RAM? PSU? I'm also looking into adding a 2nd SSD with higher capacity
I don't know exactly what needs to be upgraded. GPU,CPU,MB, PSU? all of them are pretty old to current standards.
6) Will you be overclocking?
no
24 inch, 1920x1200 max res
asap
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Fast transfer speed between the hard drives.
64 bit Windows 7 Pro - no plan on upgrading to windows 8 9 10
Thank you in advance!
Current System:
i5-2400 @ 3.10GHZ
12GB RAM:
California
no
asap
