upgrading motherboard
OldDeadOne
Are most newer motherboards ATX size? My old gigabyte motherboard is ATX(12 X 9) and I'd rather keep the tower I have with it. I'm wanting to upgrade from my dual 1ghz to either 2 dual core or 2 quad core system. Any suggestions?
Almost all enthusiast boards are ATX single socket types now that mulitiple cores are available on one cpu. You will find that even a single dual core 2 (core 2 duo) chip will perform light years better than your previous setup.
For dual socket solutions if you really want to go that route, you are looking at Xeon boards (workstation and server class). They are a few out there but (as your older board) have a fairly high price tag.
But to kinda repeat myself, the ATX board standard/size has not really changed and you should have no issues finding and installing the larger size board in your case. The multi core cpus have pretty much eliminated the mulit socket enthusiast market.
further unsolicited ramblings.
A quad core single cpu will just amaze you. Consider the Gigabyte DQ6 series (top of the line) as they have the beefy cpu voltage requlation circuity and top of the line "overbuilt" standards you are used to with your dual socket. The all "solid" capacitors design is used by several manufactures and that would be something else I would suggest you look for as it appears, like me, you like to hang onto equipment for a while.
But I cannot stress enough how much performance has improved, you will not miss your dual socket, (other than the "omg thats cool" factor).
A post down in the server section will probally reap some suggestions, I just went to newegg, one of the largest online retailers and found no dual socket LGA775 boards offered. As I mentioned, there are a couple out there but workstation or server class.
