Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I don't know for sure, but I doubt you'll notice a *huge* difference. According to newegg, XMS 2700 is supposed to run at 2-3-3-6, and value select only lists "2.5" as the cas latency. I would *assume* that means 2.5-3-3-6, but I don't know for sure. What are your memory timings like?
And no, your motherboard doesn't support dual channel DDR.
I wouldn't say it's worth the cost, unless you had a memory upgrade planned anyway. Or, unless your current timings are something like 2.5-4-4-7.
