Upgrading Laptop GPU?
vanman
Hi everyone I apologize in advance if this is the wrong thread.
I have a Toshiba Qosmio X300-02K with the nVidia 9700m gts and I want to upgrade it to the max I can seeing how its having a little issue with modern warfare 2 which I think would be a 9800m gtx.
any thoughts?
Thank you.
Andrew
I think you'll find it's cheaper and easier to just purchase a new laptop. I'm not sure if Toshiba ever put the 9800m GTX into that particular model - But even if they did, you would somehow have to acquire (Which means ebay, and notebook GPU's are typically expensive), and then you would have to install it which is questionable as that particular model may not have sufficient cooling.
