Just looking to add some bits and pieces. Waiting till there is a revision of the high end Fermi chips. The GF104 looks promising so hoping they get working on the GTX480 successor.
Basically, just looking to do the following, in order of importance:
- Overclock the i7 to 3.6GHz+
- Add more storage
- Add more RAM
My main use for the system is editing photos from a 5DMkII in Photoshop and Lightroom. Some graphic design in Photoshop, occasionally gaming, will do much more one I have a better GPU in the future. I'll also be getting rid of my 2nd GPU once I have a GPU than has 3 or more outputs so that will free up a PCI-E 16x slot.
Here is my shopping list:
- Noctua DH-14 - http://www.scan.co.uk/Products/Noctua-NH-D14-Dual-Radiator-and-Fan-Quiet-CPU-Cooler
- 2 x Samsung F3 1TB - http://www.scan.co.uk/Products/ss1T...3-SATA-3Gb-s-7200rpm-32MB-Cache-89-ms-NCQ-OEM
- 3 x 2GB OCZ 1333MHz Triple Channel i7 Kit.
- Icy Box IB-555SK - http://www.scan.co.uk/Products/Icy-Box-IB-555SK-for-5x-35-SATA-SAS-HDD-Backplane-into-3x-525-bays
- Lycom PE-103 x2 Port SATAII PCI-E controller Card - http://www.scan.co.uk/Products/Lyco...s-PCI-E-Controller-Card-with-NCQ-PC-MAC-Linux
Some quick things to ask:
- Will the Noctua DH-14 clear the ram and heatsinks on a ASUS P6T Workstation Professional?
- I want to replace the Noctua stock fans with black or ones with blue LED's. Noise doesn't concern me. Any suggestions for the 140 and 120 fans?
- I'm looking to get Samsung F3's 1TB's since its what I already have any they are plenty fast and I trust them. These extra drives are just going to be for movie and tv season storage, so lower speed drives would be fine but I'm not sure about the 1.5-2TB drives - do these drives have any problem working with RAID cards or controller cards for 8+ drives as I may get one in the future (1-1.5years) to use in a Norco 4220 style case on a different pc.
- Will having 6 x 2GB sticks effect overclocking lots? The ram is this: http://www.ebuyer.com/product/152747.
- For the controller card, I have a single accessable PCI, PCI-X and PCI-E slot, so any card able to work on either of those is fine if you have a better suggestion.
Any suggestions, could the items suggested please be linked from UK stores if you have the time? It'd be a great help. I don't mind ordering from different places as long as the postage isn't crazy. If it's free I don't mind waiting.
[B]Current Specs:[/B]
Case - Thermaltake Armour Full Tower w/Side Window
Power Supply - Unknown 800W [Can't Remember Brand ATM]
Case Fans - 3 x 120mm front in-take, 1 x 92mm top out-take, 1 x 92mm rear out-take, 1 x 120mm rear out-take
Motherboard - ASUS P6T Workstation Professional
Processor - Intel Core i7 920 D0
CPU HSF - Intel Stock
Memory - 6GB OCZ 1333MHz CL7 (3x2GB)
Hard Drive - 2 x 74GB 15,500RPM SAS Seagate Cheetah (HW RAID 0) - 4 x 1TB Samsung F3, 1 x 1TB Samsung F1
Optical Disc Drive - Pioneer 16x DVD/RW
Video Cards - NVIDIA GeForce 8800GTS 640Mbit 320bit bus (G80 core), NVIDIA GeForce 8500GT 512MB (G86 core?)
Sound Card - Onboard HD Audio
Additional Cards - None
Miscellaneous - None
OS - Windows 7 Ultimate x64
- Add more storage
- Add more RAM
