Upgrading from socket 939 to am2
cfree1961
I'm getting ready to upgrade my rig to AM2 I do not need SLI and I will be using an 8800gts 640mb card,and I'm fuzzy on the AM2 I see there is the AM2 AM2+ I know the AM2+ is quad core but is it also just AM2 compatable? and would that be the best board to use because it can use the quad core? and any suggestions on what board is good,Hope this isn't too dumb of a question and thank you in advance for any help! :)
I think you are making a bad decision.
AMD has released a Quad Core processor not too long ago, which barely competes with Intel's quad core. In all honesty, I think you are better off getting an S775 motherboard instead. If not.
AM2 is pretty much dead, some of the AM2's can become AM2+ with a BIOS update. The fact that a Phenom is a power drainer and has a ton of issues overclocking, kills it for me. You could get an S775 motherboard with P35 chipset that will blow AMD out of the water.
If you are buying an AMD for their Quad Core processors, huge mistake, right now they are simply not worth it.
If you're really not planning to get a Phenom anytime soon, I'd just go for the cheapest AM2 board that fits your needs. As of now, the X2 line is a great choice for bang-for-the-buck. So if I were in your position, I'd probably just get a good AM2 board coupled with a 6400+ BE. If you wanted to have a better long term investment in terms of being able to upgrade, I'd probably go Intel (P35 + q6600 or a higher C2D setup).
Q6600 + P35 is a killer, I suspect my setup to last me years. Stock Speed is 2.4 ghz, I got it up to 3.6 with no issues at all, just had to buy a better heatsink.
Unless you already have a processor, I would not recommend going AM2. Correct me if I am wrong, but aren't P35's comatible with Intel's upcoming processors?
p35+Penryn yes. yes, going to an am2 board and the 6400 is dead a end as few vendors are updating the bios' of am2 boards to support phenom chips. better to get a am2+ board. there are cheap ones out there. if you're actually paying money for board and cpu, make sure at least one of those components offers a bit of longevity.
Although I'd certainly go the P35+E6x50/Q6x00 route myself (I did myself last summer :D ), keep in mind that S775 is rapidly approaching its end too. At the end of this year, or maybe Q1 next year if it gets delayed, Nehalem is coming with its integrated memeory controller and new socket. So ironically AM2+ (but not vanilla AM2) is more future-proof at this time, as AMD has pledged support for even AM3 CPU's in it (assuming proper BIOS updates, which can be slow in coming). Still wouldn't recommend it though, given the current state of AMD processors compared to their Intel counterparts.
Thank You for all the replies! boy glad I didn't just go out and buy an AM2 just yet,this helps me out a great deal will mull things around for a short while again thank you all :D
At this point and time, its hard to say what to go with. Honestly, Intel has the edge in the performance market, but if you're looking for cheap, AMD is a way to go.
Both sockets, AM2+ and s775 are out, in full use, but are nearing death. Many people, like myself, bought AM2 with the word from AMD that the AM2 socket would work with future AM2+ chips. Although farfromhome mentioned AM3 and AMD's pledge that it will work with AM2+, I'd take that with a grain of salt. AMD pledged AM2/AM2+ interoperability, and look what we have now.
If I was looking to do a whole system, I'd go intel. You at least would get a years worth out of the system. And as you don't appear to have a big issue using products no longer supported (ie you're still using 939 and there have been am2 and am2+) then I'd say intel is your best choice.
