If you're happy with your current mobo and aren't going to be running Crossfire, it's not worth it. For me, I saw a night and day difference with Crossfire in some apps vs. my P965 board, but I would really rather have not made the switch otherwise.
If it ain't broke, why fix it? X38 is really an incremental improvement in terms of features over the P35 in most respects. X48 is delayed.
X38 also reads CPU temps properly.
The minimum ram multiplier on a X38 is x2 so bear that in mind if overclocking.
With an E8400, to hit 4GHz, you will need Ram that will run as DDR-2 900 minimum.
X48 isnt here yet.
I can't see how can that affect the OC
DDR2@900 means 450Mhz FSB
450 X 9 (the E8400multi) = 4050Mhz
which is how this is calculated regardless the RAM multiplier as far as I know
I dont understand what you mean.
If your ram cant reach 900MHz, you wont get to a 4GHz overclock with an E8400 on an X38 mobo.
ie if your ram maxes at 850MHz, you can only reach 9x425 = 3.825GHz.
So if you want to reach 4GHz or higher, your ram must be able to at least do DDR-2 900 speeds.
I dreaded saying that as shortly after I found that the cause of wrong temps wasnt down to the motherboard.Huh? Where did you get that info? This might sway me towards an X38 over the P35.
Robert
If you really want to upgrade again before Nehalem, wait a few months for P45 with ICH10 with integrated 10Gbps ethernet and 802.11n.
