after finding out that my 1999 Athlon system would not work with theif III (and the 10gb hard drive clanking and crashing) I figure its time for upgrading.
I wanted my stuff all at once, and in a reasonable amount of time, so i went to tigerdirect.com and browsed around for a system. My first choice was a 2Ghz athlon 64 @ 1600mhz FSB... but i want to be sure of compatibility, i went for the 3ghz P4 @ 800mhz FSB
1024mb DDR ram:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=637682&sku=U10-4911
GeForce fx 5700Le
http://www.tigerdirect.com/applications/SearchTools/item-details.asp? EdpNo=716809&sku=P450-8511
Motherboard:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=608866&sku=D452-2106
3.02Ghz cpu
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=998913&sku=CP2-P4-30008PC
i left out the powersupply, windows xp home, hard drive, and the heatsink from the list above, which all totals to 856$. I dont know much about newer computer parts, and im wondering if all of the above are a good choice for gaming. I dont want to upgrade for at least another 4 years.
1024mb DDR ram:
GeForce fx 5700Le
Motherboard:
3.02Ghz cpu
