Upgrading, few questions
Hot Sauce
Hi guys I'm going to be buying a new DVD Writer, possibly a new Computer Case, and if need be, a new PSU.
1.) I have a POWMAX 350W PSU right now, and my system is in my specs. If I get a DVD Writer will I need to upgrade my PSU?
2.) If I get a new Computer Case will I need to get a new PSU?
3.) I want to get both, if I do will I need a new PSU?
I've been looking at items from www.ncix.com (Canadian store) and I've picked out some items.
Here is the list of DVD Writers:
http://www.ncix.com/products/index.php?minorcatid=1015
And heres the one I'm thinking of getting:
http://www.ncix.com/products/index.php?sku=16202&vpn=GSA-4167B&manufacture=LG Electronics
4.) I'm on a pretty low budget, and I want to upgrade only using about $100-150 CA. What do you think of the DVD Writer I picked out, and is there any other ones on the list that look like a good deal?
5.) What are some things I should look for in a new Computer Case? Right now mine only has a couple 80mm slots, and I've only used one.
Well based on the Rig in your sig, I don't think you'd have to get a different power supply just because of the added optical drive. On the other hand, if you're going to get a new case anyway, get one with a decent power supply in it! After all a lot of Antec cases are basically free when you consider the cost of the PSU in them. Powermax is not recommended.
What are you looking for in a case: Better ventilation, window, smaller or larger, etc...? What do you have now? If you're just looking for something basic, you'd have a hell of a time beating this deal on this Antec Case w/350w PSU at Newegg for $58.99.
I have no idea what kind of case I have right now. I'm looking for some better ventilation, and maybe something that looks better. The one I have right now is VERY basic. Two 80mm case fan slots in the back, one of them occupied.
I'm looking at this one right now:
http://www.ncix.com/products/index.php?sku=14109&vpn=CS-51WBK&manufacture=Logisys Computer
It comes with a 450W PSU but then looking at the reviews people say that it is really crappy, something about the PSU only have 5 connectors, and something saying that it might blow up.
I'm looking to pay up to around $70 CA for a new case. I come accross cases that seem pretty good, but then looking at the weaknesses in the strengths/weaknesses section makes me shy away from it.
Thanks for your help.
The Antec case looks pretty good, you can't go wrong with Antec, but I'm not too keen on ordering hardware online; the shipping charges, the duty(?). Plus thats 58 USD, so add on an extra $10 or so.
I think I want a case with 120mm slots, theres a lot more advantages than 80mm.. right?
Ahh, Canadian Eh? If I were you, I'd read up on this thread; then get my butt over to http://www.tigerdirect.ca. They've got a huge selection, and no duties! Also, I'm not saying you have to change your PSU, but a case upgrade is a good opportunity to get a better one at a very cheap price.
*Edit* The main advantage of a 120mm is better airflow, with less noise. 1 120mm is better than the 2x80mm setups.
