Upgrading dell 4550
mxrider131
I have a dell dimension 4550 2G P4, 256Mb, 400 Mh bus clock, geforce mx 420. I'm looking to make it into a strictly gaming computer that I can hook up to my tv and play. I was thinking of getting 1 gig of ram and the geforce 7900gt xxx graphics card. From reading around it seems that some people say that I have limits on what i can put on a dell. So my question is will an upgrade of ram and a card be enough to make it a kick azz gaming comp or will i need to upgrade other components. thank you
First off, that is an AGP slot. You can't use a 7900 GT in it... 2nd, it doesn't have a good enough power supply. You will also need to increase your RAM & all taht good stuff. If I were you, I would try to sell everything that you have and rebuild a new system. Even if it's a Sempron 3100+Epox mobo for 89 bucks, it will be more powerful than yours. Seriously... then you can pick up a 6600 GT. Or you can spend a few extra bucks more to get a s939 Opteron 144 & DFI ULtra mobo and a 7600 GT. w00t!
I wouldn't try to upgrade that. Sell it, build a new system from scratch
noobtech said:
Thats what I just said. :(
he is reinfocing your statement :p
yeh do what noobtech said...the worst thing about dell is in the future their comps dont really leave an upgrade path (talking about their mid end and lower pcs)
if you plan on playing on regular tv, just buy a 9800 pro used or something, it should be fine at 640x480 for a while. You might want to buy another 512 for cheap to go with it too.
Thats your best bet IMO if you want to upgrade on the cheap, otherwise you should do what the above posters suggested.
Bingo. :)
thats what i figured. Then I'm gonna need a little help. I've been out of the comp loop for a few years. I will have about $1,000 to spend(including monitor, keyboard, etc) I can build it but i don't know whats good anymore. Can you give me some help on what to put in it to make it a kick azz gaming computer or if theres a complete package you recommend that would help me. thanks
Qty. Product Description Unit Price Savings Total Price
1 ASUS A8N-SLI Socket 939 NVIDIA nForce4 SLI ATX AMD Motherboard -
Retail <http://www.newegg.com/Product/Product.asp?item=N82E16813131524>
Model #:A8N-SLI
** This item is warranted through the product manufacturer
<http://www.newegg.com/CustomerService/ContactManufacturer.asp> only.
what's this? <http://www.newegg.com/Product/PolicyNonRefundable.asp>
Add item to Cart Add this item to your cart
<http://secure.newegg.com/NewVersion/Shopping/AddtoCart.asp?submit=ADD&I
temList=N82E16813131524|1>
$108.00 $108.00
CD/DVD Burners (RW Drives)
<http://www.newegg.com/ProductSort/SubCategory.asp?Subcategory=5>
1 NEC 16X DVD±R DVD Burner Black IDE/ATAPI Model ND-3550A - OEM
<http://www.newegg.com/Product/Product.asp?item=N82E16827152058>
Model #:ND-3550A BK OEM
temList=N82E16827152058|1>
$37.99 $37.99
Internal Hard Drives
<http://www.newegg.com/ProductSort/SubCategory.asp?Subcategory=14>
1 Seagate Barracuda 7200.9 SATA NCQ 3Gb/s ST3160812AS 160GB 7200
RPM SATA 3.0Gb/s Hard Drive - OEM
<http://www.newegg.com/Product/Product.asp?item=N82E16822148105>
Model #:ST3160812AS
temList=N82E16822148105|1>
$83.00 $83.00
Memory - System
<http://www.newegg.com/ProductSort/SubCategory.asp?Subcategory=147>
1 Patriot 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 400 (PC 3200)
Unbuffered Dual Channel Kit System Memory Model PDC1G3200ELK - Retail
<http://www.newegg.com/Product/Product.asp?item=N82E16820220060>
Model #:pDC1G3200ELK
$20.00 Mail-in Rebate
<http://images10.newegg.com/UploadFilesForNewegg/rebate/SH/Patriot20-220
-060Apr01Apr1706fl13.pdf>
temList=N82E16820220060|1>
$91.88 $91.88
Processors
<http://www.newegg.com/ProductSort/SubCategory.asp?Subcategory=343>
1 AMD Athlon 64 3200+ Venice 1GHz HT Socket 939 Processor Model
ADA3200BWBOX - Retail
<http://www.newegg.com/Product/Product.asp?item=N82E16819103572>
Model #:ADA3200BWBOX
temList=N82E16819103572|1>
$162.00 $162.00
Video Cards
<http://www.newegg.com/ProductSort/SubCategory.asp?Subcategory=48>
1 eVGA 256-P2-N553-AX Geforce 7600GT 256MB GDDR3 PCI Express x16
Video Card - Retail
<http://www.newegg.com/Product/Product.asp?item=N82E16814130283>
Model #:256-P2-N553-AX
$15.00 Mail-in Rebate
<http://images10.newegg.com/UploadFilesForNewegg/rebate/SH/EVGA4MIRsApr0
1Apr3006jz94.pdf>
temList=N82E16814130283|1>
$189.00 $189.00
http://secure.newegg.com/NewVersion/shopping/AddtoCart.asp?Submit=ADD&itemList=N82E16813131524|1,N82E16827152058|1,N82E16822148105|1,N82E16820220060|1,N82E16819103572|1,N82E16814130283|1&preitemList=
