Upgrading computer!
andyv0x
School and light gaming (LoL, CS:S, Maplestory)
~$300, excluding tax/shipping.
3) Where do you live?
Los Angeles, CA
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
motherboard, psu, case.
Intel Core 2 Duo E6300 Conroe
GeForce 8800GTX
4GB RAM - PC6400
250GB Seagate HDD
Arctic Cooler Freezer 7 Rev 2
DVD drive
Windows 7 OS
6) Will you be overclocking?
If necessary or recommended, yes.
22" LG monitor
Before Summer ends!
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
SATA, 4 RAM slots, PCI-E
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
Yes, Windows 7 64-bit.
This will do
GIGABYTE GA-EP43-UD3L LGA 775 Intel P43 for $79.99 w/free shipping
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128380
Antec Three Hundred Illusion + Antec Earthwatts EA650 both for $114.98 ($15 MIR on psu)
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.432087
Total: $194.97
Tax: $19.01
Shipping: $11.92
Grand Total: $225.90
Or, forget about that dual core E6300 cpu at 1.86ghz and get this
AMD Athlon II X3 440 Rana 3.0ghz + ASUS M4A785 both for $127.98
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.436270
Total: $242.96
Tax: $23.69
Shipping: $11.92
Grand Total: $278.57
Los Angeles, CA
GeForce 8800GTX
4GB RAM - PC6400
250GB Seagate HDD
DVD drive
Windows 7 OS
22" LG monitor
Before Summer ends!
Actually, what you originally want is no upgrade at all. In fact, it is merely a parts replacement for a failed motherboard, a shitty PSU and a cramped case - or (more likely) you have all of those spare parts just laying around and want to build a system based on those core components (in other words, you have no spare case, PSU or motherboard). In other words, you're keeping the exact same core components, such as the CPU, GPU, memory and hard drive. Thus, don't consider that an upgrade at all - but instead, it is actually almost the exact same system in a new shell.
