I recently built a new machine and I'm not very happy with my current case - I really didn't think about it too much, and just went with a "cheap" one. I look at this as my starter home - I've figured what I do and do not enjoy and want to move on up.
My current case is the BitFenix Outlaw
What I don't like:
Poor cable management - no where to really route the cables behind the motherboard tray.
Odd motherboard placement - it's upside down, which makes some of the cable management even more difficult.
Rear facing hard drive bays - I really dislike this, it makes the entire interior look like more of a jumbled mess.
Front fans are covered, little air flow.
What I do like:
Good size, easy to work in.
Lots of fan locations.
Simple look, nothing over the top.
These are the requirements for my next case:
Sideways facing, potential removable hard drive bays.
Plenty of room for cable management behind the motherboard.
Enough space for my push/pull-configured Kuhler 620.
Simple look.
I haven't decided if I want a silent case or not, I do have them in this listing. Odds are, I won't use the side fans, and would potentially put a window in it's place. These are the cases I have for consideration so far, so if anyone has some input or perhaps additional insight - it'd be great!
Fractal Design Arc Midi
Fractal Design Define R3
Corsair Carbide 300R <-- Wish this had grommets
Antec P280
I'm really leaning towards the Arc Midi. Everything will be sleeved and kept neat, so the case will be very clean internally. Big reason why I want the grommets!
I should add that since I'm in Houston, I have Microcenter, Frys and Directron to choose from, along with Amazon and Newegg.
What I don't like:
What I do like:
Simple look.
Antec P280
