Upgrading Backbone of our network - Looking for advise
Discussion in 'Networking & Security' started by Space_Ranger, Mar 18, 2015.
  1. Space_Ranger
    Space_Ranger Gawd
    630
    Jul 13, 2007
    Hello everyone,
    I'm about to embark on the process of upgrading our backbone switches from 1Gbit to 10Gbit, and was wondering if I should go all-fiber for the backbone (All SPF+), or go with 10Gbase-T with SPF+ uplinks?
    Basically, I'm debating between getting the Netgear XSM7224 or the Netgear XSM7224S. Any thoughts or possible pitfalls I should be concerned with?
    Thanks for taking the time to read this,
    - Space
  2. bds1904
    bds1904 Gawd
    1,004
    Aug 10, 2011
    SFP+ is generally uses less power and the add-in NIC's are cheaper. Honestly, the downfall is the lack of interchangeability/cross-compatibility on DAC's. Generally crossing brands of optics works but if DAC's is your goal it can get dicey. Long range capability & low latency is also nice. Fiber is cheap and generally easy to work with especially if you aren't new to it. If your upgrade involves running wire, i recommend using the best fiber you can afford/justify, taking the distance into consideration. Future-proofing for 40Gb & 100Gb could be attractive, just be sure to run a minimum of 5-pair (10 strand) fiber on long distance runs.
    10Gbase-T is just about standard for new servers with 10Gb capability built in. You are seeing less and less SFP+ based NIC's built in. Standard CAT6 patch cords can be nice in a data-center is nice if that's what you are set up for (if you have fiber trays as well it's not really an upside). Downfall is shorter distances, higher latency and higher cost for add-in NIC's. The latency could be enough to warrant using optical based media in storage network environments. We aren't talking huge difference but in the storage world it makes a difference.
  3. stormy1
    stormy1 [H]ard|Gawd
    1,048
    Apr 3, 2008
    Something else to consider is single mode vs multi-mode fiber.
    I have been going to all single mode for runs between rooms/floor, I think it is more future proof and the price difference is not great in some cases cheaper than om4 which is the min. I would go with.
  4. Space_Ranger
    Space_Ranger Gawd
    630
    Jul 13, 2007
    Thank you everyone for your responses so far!
    Some of the devices that will be hung off the backbone are high-end storage units (Thecus N16000V + N16000 add-on unit for 108TB of storage). I'm leaning towards SFP+'s for the majority of the connects to the backbone anyways. Thanks for validating some of my thoughts as well. :)
    THANK YOU!! The XS3700-24 is something that is a perfect fit. I get the better of both worlds (10Gbase-T and SFP+'s). 1-2 months wait on Amazon.. I'll have to hit up my other vendors and see what the pricing/availability is like.
    I agree. Everything I'm planning out going forward has been Single-mode Fiber. Thanks for backing my thoughts up!
  5. bds1904
    bds1904 Gawd
    1,004
    Aug 10, 2011
    Forgot to mention that, thanks for pointing it out. I tend to forget that because the standard fiber I work with is all SM, even within the same room. Our engineers spec SM fiber for everything so cable routes are less of a concern. I know of runs in a 75x100 building that are 900ft because of the route it has to take to avoid other cables/trays/equipment/frames.
  6. stormy1
    stormy1 [H]ard|Gawd
    1,048
    Apr 3, 2008
    If its in the same room usually I can hit it with a dac. If not I would likely use single mode also.
    The price savings with a dac makes it hard to justify fiber for short runs.
    Hmm I may be able to justify it using uniformity as an argument.
    You got me thinking.
    Thanks!
  7. Space_Ranger
    Space_Ranger Gawd
    630
    Jul 13, 2007
    Seems as though the ZyXEL XS3700-24 is a rare commodity... I can't get my hands on 1 for at least a month or two.. :(
    Any other suggestions for the switch? I'd prefer to have as many SFP+ ports as possible on the switch..
    Thanks for everyone's contribution so far! :)
  8. diizzy
    diizzy 2[H]4U
    2,602
    Nov 6, 2008
    Did you contact Nextwarehouse?
    //Danne
  9. Space_Ranger
    Space_Ranger Gawd
    630
    Jul 13, 2007
    The best I was able to do was to have them backordered, with a ship date of 3/31. That's only 2 weeks out so I can deal with that. I did not try Nextwarehouse however.
    Thanks,
    - Space
  10. diizzy
    diizzy 2[H]4U
    2,602
    Nov 6, 2008
    I see, please report back on your experience
    //Danne
  11. Space_Ranger
    Space_Ranger Gawd
    630
    Jul 13, 2007
    Most certainly will. Thank you for the pointer to the ZyXEL equipment. Was able to get 2 of the 3700's instead of just 1 Netgear unit... :)
  12. Space_Ranger
    Space_Ranger Gawd
    630
    Jul 13, 2007
    Well... I've sent an inquiry to NextWarehouse, as my supplier just informed me that my 3/31 shipdate is now 4/30... *sigh*... Anyways, I'm waiting to hear back from Next as to whether or not these units are still unicorns... I can't find ANYONE who has any in stock. :(
  13. Nate7311
    Nate7311 2[H]4U
    3,312
    Jan 11, 2001
    Who all have you checked other than the general Google shopping stuff?
  14. Space_Ranger
    Space_Ranger Gawd
    630
    Jul 13, 2007
    Well, as we're a non-profit, I went looking through our "sanctioned" vendors (Govconnection, CDW, etc.). Amazon has a 1-2 month wait, Newegg doesn't carry it. Not going to go with just ANY merchant, so whomever has it, I have to check their reliability and whether or not they are acceptable for our organization.
  15. Nate7311
    Nate7311 2[H]4U
    3,312
    Jan 11, 2001
    I checked with my distributors and their ETA is 4/26.
  16. Valnar
    Valnar 2[H]4U
    3,054
    Apr 3, 2001
    Yes. You want to use Netgear as a 10GB backbone. :p
  17. diizzy
    diizzy 2[H]4U
    2,602
    Nov 6, 2008
    @ Space_Ranger
    It's in stock at several etailers here in Sweden and in Europe overall but that doesn't help you really...
    //Danne
  18. Space_Ranger
    Space_Ranger Gawd
    630
    Jul 13, 2007
    Unfortunately, it doesn't :(
    Looks like I'm just gonna have to wait it out. I'll get my units eventually, just puts a hurting on my schedule.. :(
  19. Space_Ranger
    Space_Ranger Gawd
    630
    Jul 13, 2007
    And the delays just keep on coming... From the Zyxel rep.
    “This is a brand new product for us and we’re still waiting on our initial stock.
    (The slow down, and now trucker strike at the ports of Long Beach and Los Angeles didn’t help us any, either!)
    So far, I show we’re expecting our initial stock to arrive May 20th.
    Like I said… brand new product.
    John A. Berrios”
  20. Nate7311
    Nate7311 2[H]4U
    3,312
    Jan 11, 2001
    My Vendors are quoting me 5/15 now as well.
  21. diizzy
    diizzy 2[H]4U
    2,602
    Nov 6, 2008
    *sigh* Still available here in the Nordics :)
    //Danne
  22. Nicklebon
    Nicklebon Gawd
    550
    May 22, 2006
    Since you used high end storage and Thecus in the same sentence these may out of your price range, but Arista makes reasonably priced high density 10Gb SFP+ based switches.
  23. Space_Ranger
    Space_Ranger Gawd
    630
    Jul 13, 2007
    @nicklebon
    Sorry if my non-profit organization doesn't fit the profile for high-end enterprise equipment.
    I've already purchased 2 of the Zyxel units. I'm just keeping the thread up to date on where things are at since I was asked to report back on how things work out.
    Your insulting input has been duly noted.
  24. Nicklebon
    Nicklebon Gawd
    550
    May 22, 2006
    Take it how you like but no insult was intended. I was merely pointing out that the Arista boxes may be priced out of your range given what you considered high end. Now if want to know a real insult we can discuss your lack of good judgment. How does your non-profit feel about purchasing newly introduced product with no track record? When you have no budget to speak of buying unproven equipment is foolish. Every vendor produces bad products especially when they first enter a new market. Usually the way these bad products are fixed is by offering different products leaving the early adopters to buy the new models. Large customers can of course use leverage to work out trade in deals or just very large discounts. Small purchasers OTOH get stuck with crap gear or writing another check they can't afford. Best of luck with your purchase.
  25. diizzy
    diizzy 2[H]4U
    2,602
    Nov 6, 2008
    You do realize that Zyxel has been around in this network segment for years...?
    //Danne
  26. Nate7311
    Nate7311 2[H]4U
    3,312
    Jan 11, 2001
    I think Nikelbon's referring to the random chance that will be the piece of garbage that every vendor periodically brings to market. And on a shoestring budget, is that an appropriate risk? A valid concern, in my opinion, but at the same time, it is a calculated risk with a decent reward. I've had great luck with Zyxel's as edge or lone switches, never used one as a core though.
