Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I'm currently running the 11.10 hotfix drivers with my crossfired 4870's. I will be replacing them with a single 6970. So I need to unistall the drivers or will the system pick them up?
I would absolutely do a complete driver uninstall, even reboot in safe mode and run driver sweeper to clear out all traces of AMD,Then say no to restart when driver sweeper asks, and then shut down, remove your cards and install the 6970, then reinstall the 11.10 driver and you should be good to go.
I've seen too many horror stories of doing what your asking has caused the registry to not update and hinder performance on your newer card.
