Upgrading Air Cooling for SFF
Dmac122383
I'm interested in upgrading the cooling for my current sff-pc. I'd like to get some better fans for my case.
These are the pc components that are listed in this topic:
http://www.hardforum.com/showthread.php?t=1577768
The Case:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811154094
(I know its a cheapie, but its not too bad, and have the option of adding fans)
I'm looking to get some better fans, and these are the fans I need
1 - 80mm side fan
1 - 120mm Front fan
1 - 90mm rear fan
I'd like plain non led/colored fans, and the quieter the better. Basically I just want quality fans that will move a decent amount of air, and wont be super loud. I just ordered a sound dampening/vibration kit from www.frozencpu.com (http://www.frozencpu.com/process check out the shopping cart)
Should I just use the current fans that I have and spend the money on a cpu cooler or a vga cooler or upgrade all the fan? I will not be overclocking anything.
Thank you
