I won a little bet so Im planning on upgrading my water-cooling. At the mo Ive got a standard Water chill kit, cooling just the CPU, so i wanna add a GPU cooler and a more powerful pump and another radiator. Will i be better say having two loops since Im gonna have two pumps and two rads or would i be better with one loop like....
Res->Pump->Rad->CPU->RAD->GPU->back to Res
or
Res->pump->Rad->CPU back to Res
Pump->Rad->GPU (second loop would have a T-Line and fill port)
There isn't enough room in my case for 120.2 Radiator. I can just about fit in 1x120mm Rad and 1x80mm Rad.
Also been looking at the DangerDen 6800 water block will this fit ok on the AGP 6800. I've also looked at the Innovatek Coolmatic NV40. Anyone got any experience with these blocks?
Any advice would be great; i'm still a general novice at water-cooling.
Oh yeah, is the Zerex Racing Super Coolant any good?
or
