MissingGhost
- Jan 18, 2006
My parent's PC recently broke.
I have discussed with them the best way to spend to fix this, and we have decided that we should simply upgrade the computer.
Here is what the have now:
AMD Athlon64 2800+ socket 754
2GB DDR400 OCZ RAM (2x 1GB)
DFI Lanparty-UT NF3-250 (this is what is broken since last week)
ATI 9800pro 128MB 256bit AGP
WD 120GB SATA drive
dual optical drives
3com nic
Large ATX Antec tower
Antec Truepower 430W (the first generation, when they were good)
So now I will upgrade their computer to core 2 duo:
Intel Core 2 duo E6300 255$CAN
G.SKILL PC2-6400 2GB 2X1GB DDR2-800 CL5-5-5-15 Dual Channel 230$CAN
MSI P6N SLI-FI 160$CAN
EVGA E-GEFORCE 7900 GS KO 200$CAN
keep the old WD drive
keep the optical drives
keep the nic
keep the tower
keep the PSU (I think it will work, 420W 26A of +12v)
The motherboard's manual says it will work with 20pin PSUs, and the video card comes with an adapter for the PCIe power plug.
So as you can see they were stuck with the s754/DDR/AGP kind of hard to upgrade computer, so I couldn't find an upgrade cheaper then about 830$
So here is my question: Does this setup looks good considering the goal is to build a cheap but high performance gaming PC? What would you change?
I changed the CPU form e4300 to e6300 since the price is now the same, and I changed the ram because I found some cheap 800mHz RAM. The prices include the taxes and the shipping.
WD 120GB SATA drive
dual optical drives
3com nic
keep the nic
keep the tower
