Upgrade?
OrAnGe
I currently have an Athlon 2500+ Barton and Asus A7N8X with Two sticks of Mushkin 512 PC3200 DDR CAS 2-3-2 and Two stick of Mushkin 256 PC3200 DDR CAS 2-3-2.
I was kinda looking around (I haven't read a bunch lately) but I was wondering.
A64 3500+ Winchester s939 http://www.newegg.com/app/ViewProductDesc.asp?description=19-103-498&depa=1
with
MSI K8N Neo 2 Platinum http://www.newegg.com/app/ViewProductDesc.asp?description=13-130-468&depa=0
Is that a decent choice for a new mobo and proc for the money and will the performance increase be worth it? Will it completley rape my 2500+ barton in all areas or only in some.
Or... should I just get a NewCastle A64 3500+ s939. Or is it better to get a ..... 3400+ ... 3200+ s939 and OC..... . blargg. help?
Edit. I was just reading here in the forums and now i'm thinking a A64 3200+ Winchester s939 would be the better choice for the price? http://www.newegg.com/app/ViewProductDesc.asp?description=19-103-502&depa=1
I got that combo from Monarch with 1GB of OCZ Rev2 memory so my vote would be the MSI Mobo and 90 3500 gl with your decision.
I'd say the 3200+ 939 90nm, has a 10 multiplier compared to the 9 of the 3000+. But if $ is not a concern then the 3500+ and MSI board is a good choice. The higher multi will probably help in your ocing abilities. 2.4 - 2.6 is pretty standard for this CPU as far as I have read.
