But when you finally do buy a new mobo, ram, and cpu down the line you can get a quad core.John64 said:Converting movies should be helped a lot by having a dual core IF your using decent, multi-threaded, software. Worst case scenario, you would get a (very) single thread performance increase, also you would be able to do video conversions while gaming
Either way, Dual Core is the way of the future, and if you dont pick up your Socket939 Dual core very soon, you will have to buy a new Motherboard, Ram and CPU!
