Upgrade - Which would be best
mokkapoop
I am currently thinking of upgrading my PC just a little bit. Currently I have the following:
Dell Dimension E521
AMD2 X2 3800+ 2.0GHZ 512KB X 2 CACHE
2GB DDR2 PC2-5300 667MHZ (4 X 512MB)
EVGA 7600GT 256MB PCI-E DDR3
360GB SATA II (2 DRIVES)
16X SATA DVD-RW DL
305WT PSU
ONBOARD SOUND/LAN
20.1" WS Dell LCD
Now, Fry's has a few options for me to upgrade (my price range). Please tell me what would be better for me to upgrade to:
* 2gb PC2-6400 800MHZ (2 x 1GB)
* 4GB PC2-5300 667MHZ (4 x 1GB)
* AMD X2 5600+ 2.8GHZ 1MB X2 CACHE
Would it be benificial to do any of the upgrades above? I play games (DOD Source and BF2, possibly LOTRO soon, not sure though. I rip dvd's, build websites, photo editing.
Would it better to go to 2gb of 800mhz ram or go to 3 or 4gb of 667mhz ram?
Most games do not currently benefit much if any from more than 2gigs.. But like always that will change in the within next couple of years.. Photo shop and video authoring/ripping software can benefit from more than 2 gigs in some situations..
You have a Dell, oc options are pretty limited.. So the fastest ram it supports would be somewhat better.. But having a faster cpu, or gpu would get you more bang..
Most games do not currently benefit much if any from more than 2gigs.. But like always that will change in the within next couple of years.. You have a Dell, oc options are pretty limited.. So the fastest ram it supports would be somewhat better.. But having a faster cpu, or gpu would get you more bang..
agreed
Better Video Card and CPU would do the job. x2 5600+ and 8800 GTS 320MB. And Thermaltake Graphic Card power supply cause Dell powersupply is crap.
In general, a size upgrade in RAM is always more beneficial than a speed upgrade in RAM. However, if you buy 4 Gigs, you will need to migrate to a 64-bit version of Windows in order to see it all. Otherwise you will be limited to 3.2 Gigs. If you don't want to upgrade the proc, buying the third gig of RAM may prove beneficial. However, DDR2 RAM must be installed in matched pairs in order to enable DDR2 speeds, so I'd just replace two of your 512M sticks with 2 1 Gig sticks.
Mark.
