WarningFromSpace
- Jun 12, 2006
Greetings,
I am currently seeking advice on what to upgrade/replace for a Planetside 2 specific gaming rig with video capture possibilities. Price is flexible around 600.00. All current hardware can and will be reused if possible.
Currently research has resulted in the possibility of sticking with the 2500k. The replacement CPU for the 200-220 range seems to be the 3570k which is comparable. Overclocking will be done as CPU cooling and case airflow is great.
Big question is on such a small budget would upgrading be favored to overclocking?
Planetside 2 seems to be very CPU intensive while compatibly light on graphics card. I will begin scouring the PS2 post to identify people who have upgrade specifically for the game. For those who stumble across this post I would appreciate your input whether or not you play. Thank you [H]ardOCP!
Current specs are:
GFX: Radeon HD 6850 1 GB
CPU: i5 2500k (stock)
CPU cooler: Antec kuhler 620
HDD: 2x 1tb Segate 7200rpm
PSU: Corsair CMPSU-550VX
RAM: G.SKILL Ripjaws (2x4g) DDR3 1600
MB: ASRock Z68 Extreme3 Gen3
Sound: onboard
Monitors: 27 & 24 @1920x1080
I am not near a Mircocenter or Frys.
No peripherals needed
If any rules have been broken I will delete right away
Current specs are:
Sound: onboard
