Upgrade video card
1st Sgt. Burke
Im looking to upgrade a video card for my gateway system. I dont really want to buy a new power supply so I was curious what I could get away with that may be a bonus.
System is a Gateway FX-6800-01e currently has a 4850 512mb
I would like to get a little boost to help with newer games and definately get DX11 in some shape or form. Im planning on building a gaming rig later on early next year but would liek to keep this rig until then.
Any suggestions would be appreciated.
If the system can power a 4850, it should be able to power a 6850, possibly 6870. Both parts use less power than the 4870 in idle. The 6870 uses slightly more power under load.
6850/6870 Power usage: http://www.bit-tech.net/hardware/graphics/2010/10/22/ati-radeon-hd-6850-review/9
4860 Power usage: http://www.techspot.com/review/103-asus-radeon-4850/page10.html
Yeah, like he said, you should be able to support a 6850 and depending on the quality of your PSU, you may be able to support a 6870 or 560.
With your current setup I'd get a 6870. Optionally, if you'd like drivers, get a 560 Ti.
Manufacturer: Gateway.
Part Number:FX6800-01e.
General
Type Personal computer .
Product Form Factor Tower .
Width 7.5 in .
Depth 11.7 in .
Height 18.3 in .
Weight 31.3 lbs .
Color Jet black .
Processor
Type Core i7,
Intel i7-920 / 2.66 GHz .
Multi-Core Technology Quad-Core .
64-bit Computing Yes .
Installed Qty 1 .
Max Supported Qty 1 .
Processor Main Features Hyper-Threading Technology .
Mainboard
Chipset type Intel X58 Express .
RAM
Installed Size 3 GB,
16 GB (max) .
Technology DDR3 SDRAM .
Memory Speed 1066 MHz .
Form Factor DIMM 240-pin .
Features Triple channel memory architecture .
Configuration Features 3 x 1 GB .
Storage Controller
Type Serial ATA - Integrated .
Controller Interface Type Serial ATA-300 .
Storage
Hard Drive 1 x 750 GB,
Standard - Serial ATA-300 - 7200 rpm .
Hard Drive (2nd) None .
Hard Drive (3rd) None .
Optical Storage
Type DVD±RW .
Disc Labeling Technology Labelflash Technology .
Optical Storage (2nd)
Type None .
Storage Removable
Type None .
Monitor
Monitor Type none. .
Graphics Controller
Type Plug-in card .
Graphics Processor / Vendor ATI Radeon HD 4850 .
Video Memory 512 MB .
Audio Output
Type Sound card - Integrated .
Sound Output Mode 7.1 channel surround .
Compliant Standards High Definition Audio .
Speaker(s) 2 x Right / left channel .
Keyboard
Keyboard name Premium Multimedia Keyboard .
Input Device
Type Mouse,
Keyboard .
Mouse
Mouse technology Optical .
Mouse interface USB .
Mouse features Scroll .
Telecom
Modem Fax / modem .
Max Transfer Rate 56 Kbps .
Protocols & Specifications ITU V.92 .
Networking
Networking Network adapter - Integrated .
Data Link Protocol Fast Ethernet,
Ethernet,
Gigabit Ethernet .
Printer
Type None .
Expansion / Connectivity
Expansion Bays 3 (total) / 2 (free) x Front accessible - 5.25",
2 Front accessible - 3.5",
2 Internal - 3.5" .
Expansion Slot(s) 1 (total) / 0 (free) x Processor - LGA1366 Socket,
6 (total) / 3 (free) x Memory - DIMM 240-pin,
2 (total) / 1 (free) x PCI Express x16,
1 PCI Express x4 .
Interfaces 8 x Hi-Speed USB - 4 pin USB Type A ( 2 in front ),
2 x IEEE 1394 (FireWire) - 6 pin FireWire ( 1 in front ),
2 x Display / video - DVI-Analog/Digital (dual link) - 29 pin combined DVI,
1 x Mouse - Generic - 6 pin mini-DIN (PS/2 style),
1 x Keyboard - Generic - 6 pin mini-DIN (PS/2 style),
1 x Network - Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45,
Audio - Line-in - Mini-phone stereo 3.5 mm,
Audio - Line-out - Mini-phone stereo 3.5 mm,
1 x Microphone - Input - Mini-phone 3.5 mm,
1 x Video - S-video output - 4 pin mini-DIN,
1 x Modem - RJ-11,
2 x Storage - eSATA-150 - 7 pin external Serial ATA .
Power
Device Type Power supply .
Power Provided 500 Watt .
Operating System / Software
OS Provided Microsoft Windows Vista Home Premium Service Pack 1 64 Bit .
Software CyberLink Power2Go,
Norton 360 (60 days trial),
Microsoft Money Essentials,
Microsoft Office 2007 Home and Student Edition (60 days trial),
Microsoft Works 9.0 .
Manufacturer Warranty
Service & Support 1 year warranty .
Service & Support Details Limited warranty - Parts and labor - 1 year .
Card Reader
Card reader 15 in 1 card reader
I wonder why people who buy Gateway or Dell, whatever are lucky to have eSATA, Firewire etc. on their motherboards while people who look to build their own system have to hunt down motherboards that have those kinds of features, AND the media card readers.
Anyway, I know it says 500 watt power supply. But, if you look on the side of the power supply after removing the side panel, you should see where it says 12V. Then obviously if it says 18A twice you might have enough for say a GTX460 with room to spare. I'm just saying this so you know just in case.
