upgrade to XP64mobo and cpu or "FAST" memory?
EquaLiZr
im debating if i should upgrade my motherboard (staying AGP) and get an athlon XP 64 chip prob 3200 or 3400+ or........get some kingston hyper X CL 2-3-2-6 1T or OCZ gold edition 2-2-2-5 and overclock the shit out of my XP 2500+ mobile.
The memory i have right now will do 220fsb @3-3-3-11 2T with voltage maxed on my Abit NF7-S rev#2 and the cpu will do about 2450mhz.
Video card is the X800pro modded to the XT with the speeds 520/520.
i know the new cpu and mobo are more expensive but then im still stuck with AGP :( but ill have the XP 64 processor and might be able to overclock it a bit more with my generic memory?
IF i pick the memory, which one should i get? If i get the mobo, which one should i get? and same with cpu (cant be more than $250can)
dropping cash on ram is foolish now. DDR1 won't be around for anything but the A64, and should you ever upgrade to one of those, overclocking your memory won't do shit for memory performance.
Also, what is an AXP64? Are you referring to an Athlon 64?
Here's what I'd do.
Stick with what you have. It is plenty fast enough given your current card.
Save up, and then buy a 939 board, with a 939 venice. Ebay the old video card, and buy a similar PCI-E part, worst case it costs you ~$30 to make the switch from AGP to PCI-E cards.
yes i meant athlon 64
and yes i will be upgrading to that prob next year when it starts to phase out. I see it this way.. If i get the ram, ill be good for like 3-4 years and ill be able to hit high FSB's
