Upgrade to SLI?? Questions also...
rbarr110
Ok - I currently own a EVGA 7800 GT
Performance
NVIDIA GeForce 7800 GT
445 MHz GPU
20 Pixel Pipelines
400 MHz RAMDAC
Memory
256 MB, 256 bit DDR3
1070 MHz (effective)
34.24 GB/s Memory Bandwidth
http://www.evga.com/products/moreinfo.asp?pn=256-P2-N518-AX&family=22
I have had it for almost 7 months now and it started giving me corrupt screens and all kinds of artifacts, started just in games, now happens just on the desktop. I have been approved for a replacement and need to send it in.
Since it will end up taking over a week, maybe up to 2, to get it back, and really dont want to be without my desktop for too long, am considering buying another 7800 model card and use in SLI mode when I get my card back.
I have read that the cards dont have to be identical, but I am assuming they should be very similiar in clock speed? I dont want to spend a bunch of money again, and if I can get by with a slower card that will still give a performance boost over running the card by itself, I may run out and pick up another card.
Any suggestions on what I should do or recomendations for cards?
Thanks
Just to be safe and to make sure you get the optimal environment for sli, I would get the same model. Just get a new or used one off of ebay. Thats what I did and I love my setup.
It just has to be the same GPU. You can have different core/mem speeds. I have a 256mb XFX 7800GTX sli'd with an eVGA 7800GTX KO edition. In the control panel the speed set for 3d mode is 470mhz.
You can use any 7800GT...they are all born in the same factory. SLI is a better technology than Crossfire.
Ok, I found, I believe the same model (all signs point to same model) at newegg that is a manufacturer re-certified unit, with full warranty for just under $200.
I can get this very quickly and then run an SLI setup when my other card is repaired/replaced. Any opinions?
Slightly diff. clock speed original was listed at 445mhz, this one is 460 for the GPU, and also slight difference in memory speed as well.
http://www.newegg.com/Product/Product.asp?Item=N82E16814130035
If it was me, i would get your card back, sell it for ~$200, save the $200 you were gonna spend on a new card, and get an x1900xt or xtx. Or maybe a 7900gtx. I think you would do better with a single card setup, especially with how much money you will have.
Just me
MH
