Upgrade to 480 or 570?
Hey all, I currently have a MSI GTX 470. I was thinking about upgrading it to a better card. Thing is Im not sure if I should go with a GTX 480 or GTX 570.
I can get a used GTX 480 for $200. I can get a used GTX 470 for $270.
Is it worth the ~$70 more for a GTX 570 over a GTX 480?
Game on 24" screen (1920x1080p)
Thanks..
At 200$ the 480 is a steal. This is quite a pickle. Depends on how cheap you get a good aftermarket cooler for the 480 if it is too loud for you.
i'd just keep the GTX 470... if you can give it a little more juice by overclocking it. at 1080P the 480 will give you a little more performance but considering you already have a good card i dont really see a reason to upgrade
Yeah, the 480 isn't that much better than the 470 at 1080p to make it worth switching at this point. Wait a couple of weeks and see what Kepler and the 78xx series brings. If nothing else, it'll force down the prices on used cards.
